gear selector shaft leaking? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2008, 08:50 PM
fisher57's Avatar
Hello everyone. Got a little problem ,the shaft that comes out of my transmission where the likage bolts to is leaking, is this an easy fix? The tranny is a turbo 350. Any help is greatly appreciated thanks.
Old 02-17-2008, 09:04 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A common leak on a t-350 or t-400;
maybe look at these threads for help:
http://www.hotrodders.com/forum/shif...ght=shaft+leak
Leaking Selector Shaft seal TH350
Old 02-17-2008, 09:16 PM
Easy, easy fix ...
I use a KD tools # KD2393 ( shown above )
Most any decent parts store has the tool for 12 to 15 dollars.
Just remove the shift lever and use the KD tool to remove the old seal and the other tool to reinstall a new seal.
Old 02-17-2008, 09:17 PM
SORRY ... Crosley was typing while I was ... and I type SLOW ...
Old 02-20-2008, 09:32 AM
fisher57's Avatar
Thanks guys for the info. I got the tool from a buddy and picked up a new seal and had the job done in less than 30 minutes.
GEar DRIVE QUESTION! Werird Noise! boneyard Buick Engine 7 02-14-2008 05:45 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 12:08 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 08:12 AM
Ford 9" leaking gear oil 7dcrzr Transmission - Rearend 15 02-01-2006 12:13 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
