Gear swap in 10 bolt rear end 1987 Cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 07:29 PM
pena0724's Avatar
Hi guy's i have a gm 10 bolt 7.5 rear end in my 87 cutlass i believe the gr is 2.13 because the gears are marked 22.47 i want to switch to a 3.73 or 3.42 my friend gave me # 3 carrier Richmond posi unit which had 3.73 gears i was told i need to go with the thicker gears is this so and if so why? my question to every one is should i go with 3.42 or 3.73 I would like to do some highway driving but i want a good kick off the line this is what i have 350 turbo 3,000-3,500 stall 355 Chevy alum heads.
Old 07-16-2009, 10:09 PM
fast68's Avatar
likes chevy trucks & boobies
2.21 2.28 2.56 2.73 2.93 3.08 are the ratios it can be if its stock factory highway common smogger car ratio still
3.42 would be about as deep as i would go if you plan on alot og highway driving rather than in town driving
its not gonna be real good on fuel mileage anyways with how its built, so i wouldnt be so worried
or put in a 2004r trans and then 4.11 axle or so,
Old 07-16-2009, 10:27 PM
ericnova72's Avatar
More for Less Racer
Are you sure it is a 3-series carrier?? Only the 2-series carrier would require you to need a thick gear for the 3.42 or 3.73 gear set.
Rear end swap for a GM 10 bolt jpd37 Transmission - Rearend 6 05-07-2009 09:14 AM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
10 bolt posi 8.5" rear end 406chevelle Transmission - Rearend 7 02-23-2004 09:51 PM
rear end gear swap Jared Engine 3 03-19-2003 08:46 PM
