Gear Vendors - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2006, 06:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
GV unit uses a piston type pump with an eccentric on the shaft to provide pumping action.
A cone shaped friction clutch is used
  #17 (permalink)
Old 02-28-2006, 09:47 AM
diver's Avatar
cost!!!
If I were you I would do away with the C4 altogether. From my expreiance they aren't very strong OR reliable. The Gear Vendors OD and a ton of $$$. If you could go with a later model OD tranny from Ford, it would be a better choice.
Gear Vendors Under/Overdrive Skylark_77_455 Hotrodders' Lounge 5 02-11-2008 07:43 PM
Electronically shifted THM400 and Gear Vendors bragggf Transmission - Rearend 0 10-11-2005 08:02 PM
Gear Vendors Over/Under Siggy_Freud Transmission - Rearend 7 12-15-2004 05:13 PM
Gear Vendors overdrive slider in wa Transmission - Rearend 5 06-14-2003 11:50 AM
