gearhead wiring harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 12:44 AM
Last journal entry: dash mods
I bought a gearhead wiring harness on ebay couple years ago.It came with that orange book 'how to wire a streetrod' (CRAP book!)Harness had some issues like fuse box needed changing some wires(keyed to live),but was easy to work with.I'm just redoing some wiring and realized I never did figure out what the second relay is for.One is for the horn,Anyone know where the other went or what it's for? thanks
Old 11-01-2008, 08:27 AM
CARGUY's Avatar
im installing my harness right now came with the same book and some very vague instructions . anyway i had the same question one extra relay three extra wires from it, hope someone has an answer id like to know also.
Old 11-01-2008, 10:37 AM
the clock and something else (can't remember) were hooked up to ignition power.I just blew a radio fuse,only it's not hooked up to the right fuse( haven't looked to see which one).Radio red and yellow wires are reversed,mine has red as full time power.I just reversed going to stereo,otherwise there would be no memory etc for stereo.
The book shows column ignition plug ground wires but none are in the harness.I just hooked it up as is,it works.
The GM light switch uses 2 power positives and only 1 in kit, so I hooked in another.
There is only 1 wire for electric fan.If I found where that relay came out i would've used it.I used the cruise wire for the temp switch going to fan relay.
If I had it out before installation, I'd check the curcuits.I can't believe how much space wiring took under the dash.
Wiring Harness Information MrBrightside Electrical 12 12-18-2007 06:58 AM
POWER accesory wiring harness 91vette Electrical 13 04-11-2006 05:21 PM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
ford wiring harness akm Electrical 6 03-13-2004 10:25 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
