gearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2009, 08:13 PM
gearing
if I run a 4.10 gear and a 265-50 r-15 tire where will my rpm's be at 65 mph.
I wanted to run a 3.73 gear but was told that I should go lower. The thing is that its still aside from the strip will occassionally see the freeway, appreciate the knowledge thanks.
Old 04-13-2009, 08:51 PM
prostreet6t9's Avatar
Differential/Driveline
You can do some calculating here>http://www.ringpinion.com/Calc_RPM.aspx
700r4, Rear gearing... DarknessSpawned Transmission - Rearend 4 03-05-2008 02:09 PM
Weight, tranny, gearing and rpm's? HemmiGremmie Engine 11 01-24-2008 10:33 AM
Gearing Question? Doubleclutch Transmission - Rearend 1 06-08-2007 05:55 PM
Is my gearing that bad? FusionMalibu Transmission - Rearend 3 07-19-2005 04:12 PM
gearing for 68 Camaro Crombie Transmission - Rearend 4 11-25-2003 07:30 AM
