gearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2005, 06:21 AM
59 f100's Avatar
rubber on the road
gearing
i have a rear end that i want to put in my truck my question is how do i tell without spliting the pumpkin what the ratio is
Old 11-02-2005, 06:31 AM
As one of the Moderators on this forum, I would like to WELCOME you here...
If you are installing another Ford rear end under your F-100......it should have a tag on it.
Similar to the one shown.......this one is a 2.79 gear ratio.
IF you are using a 9 inch Ford replacement ......why not just change the center section.? ?
Just make sure you have a way of putting fluid in it......not all 9 incher are exactly the same...
Old 11-02-2005, 06:51 AM
59 f100's Avatar
rubber on the road
i am actually putting it in my other project its a 1994 ranger i allredy put a 9" in my 59 but ther is no tag on the axle so i was wondering if there is another way to tell the rato my cusin said thet you could count the tire rotation
Old 11-06-2005, 12:22 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Jack up one wheel, put trans in neutral, turn other wheel two full rounds counting driveshaft turns (you are only turning one wheel so it turns twice as much/fast as if you were turning both wheels equally).
Old 11-06-2005, 06:11 AM
it's how many drive shaft revolutions (3revolutions=3.00, 31/2 revolutions=3.50) for one 360deg tire rotation with the car in neutral off the ground and no brake drag
tire stem at 12 o'clock for 360deg refererence, drive shaft marked to count rev's and parts of rev's, hand turn the driveshaft
? never have tried xntrick's one wheel method but it sounds correct..probably cause I always jack up using the pumpkin
Old 11-06-2005, 05:19 PM
xntrik's Avatar
we're both right. With a posi you usually can't turn just one wheel. With an open you usually can't get them both to turn equally.
Weight, tranny, gearing and rpm's? HemmiGremmie Engine 11 01-24-2008 10:33 AM
Is my gearing that bad? FusionMalibu Transmission - Rearend 3 07-19-2005 04:12 PM
Gearing for a blower? HemmiGremmie Transmission - Rearend 2 02-21-2005 05:58 PM
gearing for 68 Camaro Crombie Transmission - Rearend 4 11-25-2003 07:30 AM
what gearing do ihave 89camaroman Transmission - Rearend 0 10-04-2003 11:01 AM
