Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gearing choice for engine build
Old 11-19-2012, 10:14 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The tires are tall, I would use the 4.11's. Why shorty headers? what chassis is this.
i believe the drag strip on the island (outside Victoria) is 500ft. You want lots of gear on a 500ft drag strip.
The hiway cruise rpm will be just right wiht the 4.11's and 27.5" tires.
3000 rpm @ 100 klicks. This cammed engine does not want a slow cruise rpm.
crusing at 3000 rpm, @100Kph is just right for this motor.
rpm / gear ratio x tire diameter x 336 = speed in MPH
convert MPH to KPH x 1.613
