Gearing choice for engine build - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2012, 07:47 PM
Im am just putting the finishing touches on om SBC 355 build. I have a ford 9" with 355's in it know. My cousin has a set of 411's he offered up to me for free and I was wondering if I should take him up on it or should I stick with what I have. It is a weekend street car. Car weighs about 2500 pounds
Thanks in advance guys
SBC 355
Stock but fresh bottom end
Edelbrock Estreet heads (ported)
Edelbrock air Gap
Comp XR274R solid roller - 236/242 @50
Recomended Springs/retainers and keepers
Crane/Scorpion Full roller rockers 1.5ex/1.6in
Holley 670 street avenger
MSD street fire dist./6AL box
Standard 4 speed Saginaw (until it goes boom)
Old 11-19-2012, 08:17 PM
vinniekq2's Avatar
if you race try the 4.11s.If the diff is a complete 3rd member then changing it is quick.That car should fly at 2500 pounds
what intake?/exhaust?
Old 11-19-2012, 08:30 PM
F-BIRD'88's Avatar
Yada Yada Yada
The carb is way too small. its going to choke this otherwise great combo.
no mention of the tire diameter. It will accelerate much harder with the 4.11's.
more acceleration='s more fun. Get a 750cfm DP carb.
Prostcelica when you lash the XR274r-10 cam set cold about .004" to .006" tighter than the hot lash spec.
You will find this works very well for you. The lash will be just right when the engine is warmed up.
Old 11-19-2012, 08:51 PM
Its not a race car but might take it to the track once or twice a year but mainly a street car. Unfortunatly it is just the gear set and not a 3rd member so I cant just swap it out easly to try it. The intake is an edelbrock air gap and the exhaust is 1 5/8 shorty headers, 2.5 inch through maganflows. I was thinking od adding electric cutouts just for fun....So Vin your saying if its a street car stay with the 355's??
Hey Fbird I hear ya on the carb. Ive already been shopping for something bigger. I just have a 670 sitting on the shelf......maybe ill just leave it there. Tires are 295/55/15 mickey thompson drag Radials. Thanks for the heads up on the lash settings. I think I saw somebody else on the site recomend that as well in a previous post
Old 11-19-2012, 08:59 PM
Bye Jerks
That's 3 steps up in the gearing. It will make a big difference. You like to cruise on the highway? You probably won't like the 4:11's. If you are just looking for a harder launch, yeah, it will do that.
Old 11-19-2012, 09:10 PM
vinniekq2's Avatar
I use a 3.50 gear and its good.If I was drag racing I would gear the car for it to be at or just under redline in mt finishing gear. In my case fourth and still have O/drive to tolerate street driving
If the car leaves hard I would think theres daylight under the front tires for a short time
Old 11-19-2012, 09:12 PM
I want to try and get the best of both worlds. I will say that with the old motor which was pretty well a bone stock sbc 350 with performer intake, that holley carb, humps, headers and an "RV" cam cruised at around 2500-3000rpm at 100KMH and hit pretty hard of the line. Any idea what the highway speed woud be with the 411's knowing that the 355's ran around 2500-3000??
Old 11-19-2012, 09:19 PM
Thanks for the feed back Vin. I think what ill do is run it with the 355's in it at first and see how it is. If its a total dog off the line I can go to the free bee 411's. I just wanted to ask you guys to see what everyone would say. If everyone came back and said "it will be a total slug off the line" I would do the gear change now but it seems like im in the ball park with the 355's.
On a side not any guesstamations on 1/4 mile ET's??
Old 11-19-2012, 09:21 PM
vinniekq2's Avatar
Gear Ratio Speed Calculator
play with gears/tires trans ratios
Old 11-19-2012, 09:24 PM
vinniekq2's Avatar
over 120 mph is a high 10 second car. Ive used gears from 2.73 -- 5.57 on the street.My big block Camaro had 3.36 gears and on the high way I felt the gearing was a little steep for long trips,and it destroys gas mileage. I drove my old 67 Camaro from Vancouver Canada to Bremerton raceway Washington state,,60 mph equalled 3.700 RPM on the highway for 2 hours, 3 hour trip took 4 hours
Old 11-19-2012, 09:41 PM
Thanks for the link Vin. Thats a long way to go at 4000rpm Hey Vin you live in Vancouver?? Im on the island.
Old 11-19-2012, 09:50 PM
vinniekq2's Avatar
I live in port coquitlam.where do you race?
Old 11-19-2012, 09:58 PM
Im in Nanaimo but Im just starting to get into racing but my family is into pretty huge. They are always over on the mainland racing. Mission, ashcrost, etc. if your into racing you may know them. My uncle had a burgandy chevy II with "MID LIFE CRISIS" on the side. My cousins have a Yellow S10 with a big block, Green Vega and a Beretta door slammer with a blown hemi. Ringing any bells??
Old 11-19-2012, 10:08 PM
vinniekq2's Avatar
Ive only been to mission twice since about 2006. you can ask them if they know Rapid rory McNeil, the fat turnip Dan Madeloni,the Farmers of course. Dave Hall,Richard Johnson, We keep naming names and one will click.If you come over here,get a hold of me
Old 11-19-2012, 10:14 PM
F-BIRD'88's Avatar
Yada Yada Yada
The tires are tall, I would use the 4.11's. Why shorty headers? what chassis is this.
i believe the drag strip on the island (outside Victoria) is 500ft. You want lots of gear on a 500ft drag strip.
The hiway cruise rpm will be just right wiht the 4.11's and 27.5" tires.
3000 rpm @ 100 klicks. This cammed engine does not want a slow cruise rpm.
crusing at 3000 rpm, @100Kph is just right for this motor.
rpm / gear ratio x tire diameter x 336 = speed in MPH
convert MPH to KPH x 1.613
555 bbc dart build cam choice dav770431 Engine 15 06-05-2012 06:47 PM
dart bbc 555 build head choice dav770431 Engine 5 05-30-2012 01:22 AM
Sbc 355 Build-head Choice. VARS_85MONTE Engine 8 11-26-2011 10:03 AM
Engine build intake manifold choice Badazz93 Engine 4 02-28-2011 04:28 PM
First engine build - would a roller cam be a better choice? surfshark Engine 4 05-28-2006 06:02 PM
