Gearing VS MPH - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2013, 09:40 AM
Slammedsi's Avatar
Gearing VS MPH
I am going to change out my rear gearing to something in the 4.00 range. I was wanting to know if there is a calculator that will show what my top speed in each gear will be at 6000 rpm? Ive Googled and didn't find much. Im running a 700R4 trans and wanting to know the different mph for say a 4.10,4.56, and 4.88. Factory 700R4 gearing is 3.59:1, 1.625:1, 1.0:1, and 0.696:1. I will be running a 30.10 inch tall tire. Any help would be great.
Old 07-18-2013, 10:20 AM
hrlys4evr's Avatar
60-66 chevy truck nut
Last journal entry: Hood finally in paint
Gear Ratios Calculator, MPH, Top Speed - DragTimes.com
Try this out.
Chris
The Following User Says Thank You to hrlys4evr For This Useful Post:
Slammedsi (07-18-2013)
Old 07-18-2013, 10:24 AM
Slammedsi's Avatar
I had a friend give me a link that i believe gave me what I wanted to know. Tell me if this information sounds correct.
using a 3.73 and 700R4 @ 6000RPM
1st. 47mph
2nd. 89mph
3rd. 144mph
4th. 207mph
This information seems strange. There isn't a speed o in the truck at this time so i cant correlate this information.
Now going to a 4.88, 700R4 @ 6000RPM
1st. 36
2nd. 68
3rd. 110
4th. 158
Old 07-18-2013, 10:30 AM
Slammedsi's Avatar
Originally Posted by hrlys4evr View Post
Now that one seems to be more accurate. The one I used first Showed way to high of a mph for first gear. For instance, the 47 mph in first. But the link you gave me shows a 40mph first using 3.73 rear end. Alot better.
Old 07-18-2013, 10:45 AM
hrlys4evr's Avatar
Yep. Looks right. You can bounce it off of TCI transmissions calculator also.
Old 07-18-2013, 01:00 PM
Slammedsi's Avatar
Originally Posted by F-BIRD'88 View Post
RPM / gear ratio X rear tire diameter /336 ='s MPH
This is for when there is no torque converter slippage ( manual trans or converter locked up)
Use 355 instead of 336 for a typical stock converter and use 360 instead of 336 for a high stall.
Th700r4 gear ratios are 3.06 1.61 1.11 and .70 it is a 30% OD
The higher the rear ger ratio, the more profound the 30% taming effect when in OD (RPM reduction)
This trans is not designed to operate at full throttle when in OD. Its a cruising gear.
So when in OD, a 4.88:1 axle ratio gets tamed to 3.42:1 So don't be shy with the gear swap choice if you want this heavy truck to accelerate fast. Especially with the tall tires.
Using your math I come up with a 102.8mph. Is this the theritical top speed, Seems offly low.
Old 07-18-2013, 01:10 PM
Slammedsi's Avatar
Old 07-18-2013, 01:26 PM
Slammedsi's Avatar
Old 07-18-2013, 04:57 PM
Slammedsi's Avatar
In this 4000# truck with 30" tires and 4.88 gears you can hiway cruise fine @ 80MPH in OD @ a comfy 3000 rpm. You are not running Bonneville.
WOT in D (3rd gear) drive it will be reving 6440 @ 110MPH. You will need 500 real engine horsepower to do this.
110 MPH trap speed will run a very low 12sec Q mile
A blower on your 350
WOT @102.8MPH you need 402 real horsepower to hit this in 1/4mile ( low 13's)
Got 402 real engine horsepower?
Misprint on my th700r4 trans gear ratio's 3.06 1.61 1.00 .70 OD is 30% (.70:1)
This assumes your truck and you in it weight #4000 . it probably weights even more than this.
Trucks are heavy.
Truck weighs 3720 with me in it.
Old 07-18-2013, 08:50 PM
vinniekq2's Avatar
Gear Ratio Speed Calculator
this is easy to use and different RPMs can be subbed in easy
The Following User Says Thank You to vinniekq2 For This Useful Post:
Slammedsi (07-19-2013)
Old 07-19-2013, 07:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Various Calculators from Wallace Racing
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 07-19-2013, 09:56 AM
Slammedsi's Avatar
thanks guys! Yall got what i needed.
gearing ssonny34@yahoo.com Transmission - Rearend 1 04-13-2009 08:51 PM
gearing 1cleanmav! Transmission - Rearend 7 01-25-2008 07:37 AM
gearing 59 f100 Transmission - Rearend 5 11-06-2005 05:19 PM
Gearing help 5.0Towncar Transmission - Rearend 9 06-24-2003 08:18 PM
Help with gearing 5.0Towncar Transmission - Rearend 0 06-23-2003 05:38 PM
