gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2007, 11:25 PM
gears
i have a 73 nova i want to put new rear end gears in it. i drive it on the road alot so can't go to low. it has a 35 turbo tranny 327 motor and 26 inch tires. i was thinking 3.73 gears i think it has stock 2.73 gears how much will this new 3.73 help me. any suggestion?
Old 06-29-2007, 08:57 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
You should find out for sure what gear you have now. If it's a non posi, jack up one rear wheel. Put a mark on thr driveshaft and tire, the spin the wheel exactly 2 full turns. If it really is a 2.73, the shaft will turn 2 and 3/4 turns.
Then figure out what what driving you are doing. Mostly highway with everybody doing 70+ and your motor will be buzzing pretty high with 3.73, especially with a non-lockup auto. Lower 3's would be better IMO
Old 07-01-2007, 09:58 PM
Got 2.73's? Drive around in 2nd gear some, then do the math and realize that you're mimicking 4.10 gears. Knock off about 10% of engine speed, and that's what 3.73's will be like.
But the kick in the pants you'll get just might be worth it.
Of course you might want to stick a posi unit in there while it's apart, if it doesn't have one already. It'll only cost you for the part, since the same labor has to be done when you change gears.
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
Change 4.11 to 3.08 rear end gears cares Transmission - Rearend 4 08-13-2006 01:46 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
