Gears in a 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2002, 03:51 PM
New Member
Post Gears in a 12 bolt
I have 4:11 gears in my 12 bolt posi. If I have a 4 series carrier what is the cheapest way for me to get the rear end gears down to a decent cruise number like 3:08s. Do I have to buy a whole unit? Who are the best mfgs? Noggin
Old 01-04-2002, 03:39 AM
Tazz
Cool
You might consider a larger tire size. Borrow a friends wheels if they will fit in your wheel wells. I have just the opposit problem, 3.55 gears with 33x18.5x15 wheel/tire and I need 4.60+ to get them moving.
Old 01-04-2002, 02:55 PM
Post
I need to know if you have a truck or car rear and what year it is . I may be able to help you otherwise the carrier will need to be replaced with one for a higher gear .
Old 01-04-2002, 02:58 PM
Post
TM454, do you have a truck type or car type rear , I have a 3:73 limited slip unit for a truck and I need the one you have if its for a truck .. I just thought I would try to help us both if I could stinmar1@connectnc.net
Old 01-06-2002, 06:22 PM
New Member
Post
Noggin....Check in to some overdrive units. They work. Good speed shops have 'em.
Old 01-08-2002, 03:58 PM
New Member
Post
[quote]Originally posted by stinmar1:
<strong>I need to know if you have a truck or car rear and what year it is . I may be able to help you otherwise the carrier will need to be replaced with one for a higher gear .</strong><hr></blockquote>
Old 01-08-2002, 04:00 PM
New Member
Post
It is out of a Camaro, so not a truck rear. Can't just put taller tires. Over drive units are big, heavy and expensive.
