Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 12:56 PM
Gears
I Need To Know The Gear Numbers In My Turbo 350 Trans . I Have 3.42 Gears In Rear 25.4 Tall Tires . At About 55 Mph My Speedo Is Reading 85 Mph Way Off Please Help . I Just Need To Get Close Thanks John
Old 02-25-2012, 02:00 PM
Wiki Edits: 49
That's a pretty drastic error. You don't need to know the gear ratio of your trans as all TH-350's have a final drive ratio of 1:1. What you need to do is pull out your speedometer drive gear and count the teeth. Because your error is where the speedometer is reading high a little over 30%, you'll have to buy a new gear with about 6 fewer teeth than the one you have. Each tooth less will give you a 5% reduction in what the speedometer shows. These gears cost around $5 each.
Centerline
HotRodsAndHemis.com
"Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen
Old 02-26-2012, 06:11 PM
Gears
Today I Took My Trans Apart Today An Change The Gears Like You Said , It Didnt Make Much Different ! I Notice The Gear On The Shaft Had The Groves On A Hard Angle , I Compaired They 2 Gears Big Differents 1 Had 16 Teeth The Other Had 10 , So I Put The 10 Tooth Gear On An Put On 2 Teeth More On The Cable Gear . Put All Together An Test Drove Lol I Got Lucky Rite On The Money ! Thank You For Your Help John.ps I Redone My Camaro Rebuilt Motor Trans An Rear An Painted It Not Perfect But Its My En .
**How may gears do you want?** Do we really need the 6-7-8 gears in today's trans? CometCyclone Hotrodders' Lounge 32 11-06-2011 09:49 PM
Gears. WOW!!! American Muscle Transmission - Rearend 24 07-15-2010 10:21 AM
swapping 2.56 gears to 3.50 gears shmiv Transmission - Rearend 9 05-16-2009 10:18 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 11:17 AM
need new gears rustyrazer Transmission - Rearend 3 03-16-2003 03:28 PM
