gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 08:00 AM
gears
I have a 67 chevy C-20, and I was wondering where I could find gears? Someone changed the tranny with a turbo 350, and I think the rear has 4:56's in it. Its a sunday driver, but its way too low geared, at 55 the tach is running at about 2900. Major gas hog. Its not a dana rear, how do I know how big the ring and pinion is?
Old 04-30-2006, 08:26 AM
spinn's Avatar
turn the driveshft and count the wheels rotation. it will give you a rough idea. if its a open diff, have one person hold the other tire(its jacked up) and divide the final number by 2
if your going cruisng at 65 , i recommend a 3.08
Old 04-30-2006, 10:12 AM
Bumpstick's Avatar
Hammer and a torch
Thats about where my BBC turns at 55 in my 69 PU and it has 4.56 rear gears with 28.5 tall tires... Measure the tire height to be sure... Also take a look here to help with your figuring...
Old 04-30-2006, 11:21 AM
Why not install a 700R4 automatic OD transmission and get the BEST of both worlds.......low gears for taking off and a OD for mileage......
4.56 minus 30 percent Od = 3.19 .......in 4th gear,,,,,,
Old 05-03-2006, 06:29 PM
tranny length
this may sound like a dumb question, but whats the length differences from a TH 350 to a 700r4, just wondering for driveshaft mods.
Old 05-03-2006, 07:44 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Did that in my truck and didn't have to cut the driveshaft.
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
2:41 gears in a 81 Firebird 81FIREBIRDESPRIT Transmission - Rearend 8 03-22-2005 07:37 PM
8.5" spider gears onecoomofo Transmission - Rearend 5 06-14-2004 07:41 AM
Exploded spider gears...? (12 bolt GM) Bumpstick Transmission - Rearend 7 10-07-2003 06:00 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
