-   -   Gears? (http://www.hotrodders.com/forum/gears-9197.html)
Screamin' Eagle 09-24-2002 05:38 PM
Gears?
I have a '74 nova with the following...
350CI
Stock pistons
sportsmanII heads
edelbrock rpm intake
edelbrock 750 carb
crane Energizer Int.470 exh.470
Tci streetfighter Torque converter
Im wanting some new gears.
3.08 is what i have now but want to go to 3.73
what am i going to need to change.
also what performance gains should i see?
heavychevy 09-24-2002 06:18 PM
i have about the same set up except a bigger cam. I went from 2:73 to 3:73 and picked up a full second in the 8th mi. It was proly the best thing ive done to my car.
bigjoedo 09-26-2002 03:32 PM
Screamin' Eagle,
I went from 2.56 to 3.73 gears and it made a big difference in acceleration. The engine runs at 3700 RPM at 70MPH using a TH 350 Trans. <a href="http://www.reiderracing.com" target="_blank">http://www.reiderracing.com</a> carries Precision gears for about $155. According to many sources Precision gears are far better than other brands. Good Luck. Hope this helps.
Joehttp://www.reiderracing.com
dmorris1200 09-26-2002 07:17 PM
Also purchased precision gears from Reider for my Mustang. Don't know what trans you have but I went from 3.00 to 3.70 gears with a C4 automatic and am very happy with them. They were extremely helpful on the phone when I ordered the parts. As soon as I told them my application they set me up with everything I needed for a complete overhaul (bearings, shims, etc.). You can see a picture of the overhaul with the fresh set of gears in my hotrodders photo album. I give Reider Racing two thumbs up. :D :D
