Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gears for my combo?
Old 12-02-2011, 12:00 AM
chevyrally68 chevyrally68 is offline
gears for my combo?
I have a 68 chevelle malibu 327 .40 over with a lunati cam
th350, 2000 torque converter
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .468/.489
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
I am wondering on the gearing I should be running? I am not sure what I have in the rear now, but it is a stock 8.2gm 10 bolt 1968, but my tach says I am around 2800-2900 rpm @ 60-65mph I also have a team g single plane intake with a 670 holley vac secondaries on there, could that single plane intake be the cause of sluggish bottom end? But once it gets the RPM up it flies like a bat out of hell! Also I have 245 50 r 15 on the front and 275 60r 15 on the rear which I think calculates to 31" tall tires for the rear. Pls help I am happy with mid to top end performance but would like recommendation on gears and posi? Some have told me posi is to dangerous easy to loose control, breaking loose all the time from the road. I will be driving a good amount of highway driving and not a strip car. I will be sticking with this th350 for the time being, but next time a OD trans for sure. Sees like with my RPM at 65 could it be 3.73's? If so how can it be so sluggish down low if in fact it is 3.73 gears, dual plane intake???
