Gears and WOT shift points? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2010, 06:36 PM
Lets say my truck with c6 auto 33" tall tires shifts from 1-2 and 2-3 @ 4,500rpm with 4.10 gears. If i were to switch to 4.56 gears with the same 33" tire would the WOT shift points stay the same? I'm assuming the part throttle shifts would happen sooner but not sure about WOT shifts. Thanks
Old 12-20-2010, 08:58 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The shift point will still be at 4500..just takes a shorter time to get there..maybe have greater tire spin off the line or it may work out perfectly to your liking..
Sam
Old 12-20-2010, 09:51 PM
Thanks i was hoping that would be the case.
th350 shift adj again sooper Transmission - Rearend 5 05-22-2010 12:58 PM
85 Chevy 1/2-ton rear diff questions SUX 2BU Transmission - Rearend 26 10-10-2009 07:20 PM
700R4 shift problems with lock-up jeltonb Transmission - Rearend 8 02-27-2009 10:25 AM
700R4, only shifts @ WOT Hotwire Transmission - Rearend 13 09-05-2008 09:14 PM
700r4 shift times is this ok? evltwin Transmission - Rearend 1 04-23-2004 07:22 PM
