-   -   Gen 1 SBC Knock Sensor (http://www.hotrodders.com/forum/gen-1-sbc-knock-sensor-229526.html)
thinwhiteduke 02-13-2013 07:21 PM
G'day all, does anyone know how to rig up a knock sensor system on a sbc gen 1? , however crude ... Is a computer needed? ... Maybe a stethoscope with an extension , or a mic with a little amp and earphones would work, I dunno?
I never done it before, I see summit has knock sensor sender units, but are they just for gen 2 and 3's ? Heads are world sportsman two's..
Any u guys been faced with this task before?
All ideas welcome,
Thanks,
Duke
vinniekq2 02-13-2013 09:50 PM
have you talked to AP72? he does all kinds of auto wrecker wiring
thinwhiteduke 02-13-2013 11:35 PM
thanks Vinnie, I'll swing the question his way...!
Duke
gearheadslife 02-13-2013 11:46 PM
gen I 305/350's had them.. but where computer controlled..
my basic ccc 305 in my 86SS has one..
the TPI and tbi engines also did..
most likely could wire it to a relay to trip a msd timing retard box.. the relay acting as the on/off switch..
thinwhiteduke 02-14-2013 12:19 AM
thanks gearhead, but I just got HEI, no box.
Maybe I'm screwed???
Duke
thinwhiteduke 02-14-2013 12:27 AM
I'm not that concerned with controlling it ( by way of ignition retard ) ,
I just want to make sure I can HEAR it if its happening!!
I can't hear squat ATM and I'm 99.9% sure it's not detonating, just thought it might be cool to have some type of indication or amplification , so as to be aware.. Thanks
Duke
gearheadslife 02-14-2013 12:37 AM
Duke
WIRE IT TO RELAY AS ON/OFF trigger to a idiot light in dash.. it'll light when you are knock'n boots in engine
thinwhiteduke 02-14-2013 02:47 AM
Wire what? Are you talkin bout wiring a knock sensor? Pardon my ignorance, I CAN wire stuff, but I got nothin to wire ATM.
Assuming that yor saying to wire a knock sensor, where does that go? In the head I guess..do I have to tap a hole?or does it go in one of the water plug holes, just like a temp sender unit?
Sorry if I come across as 'dumb', please bear with me, I'm living in the past...LOL
I have never even seen such a beast ( knock sensor).
Thanks for you help..
Duke
gearheadslife 02-14-2013 02:55 AM
THEY GO IN THE block.. the sensor for a 305 is different than a 350
if you have aftermarket parts they can set them off..
you have to torque the sensor per factory manual
I'd have to look to see how they are wired.. to know what terminal to hook it to on relay
spinn 02-14-2013 03:15 AM
1 Attachment(s)
here is a page of diy knock sensor info.
thinwhiteduke 02-14-2013 04:40 PM
Thanks Spinn, that's helpful, it's the right price!,... And something I could handle..I'm studying that.
Duke
thinwhiteduke 02-14-2013 04:47 PM
Thanks gearhead, everything is aftermarket , bar the block, crank and rods.
It's starting to look like I might be need ing some form of computer .
I'm learning, so that's always a good thing!
Duke
thinwhiteduke 02-19-2013 09:46 PM
Thankyou VERY much f,bird. That's EXACTLY the kind of system I had in my mind, simple amplifier, it's just gotta work!
BTW what tranny you running in you car, is the a two speed or three speed?
Looks real quick on the u-tube vid, 👍 what's your q/mile?
Duke
ap72 02-20-2013 06:56 AM
Sorry I took so long to reply, got distracted. The links provided give you a good DIY start, BUT without tying it into computer controlled fuel/ignition you're very limited on how useful it will be. It can work as an "idiot light" so to speak but not really useful for tuning.
Also it is very easy to get a false reading with aftermarket valvetrain or sometimes pistons or a very worn engine block.
You may be better off just tuning it the "old fashioned way" with plug reading, vacuum reading, and some common sense starting points.
Custom10 02-20-2013 09:58 AM
There are some special pin HEI distributor modules that provide spark retard functions of about 5 degree's when the correct pin is wired to ground. Perhaps you could find the correct knock sensor that would allow you to do this by simply wiring the pin through the sensor to chassis ground, you may need a relay. I think some of them needed the pin to see 12 V to do the same thing.
Wire a toggle in series to disable the trigger and maybe another toggle to manually force the retard function for starting up an agressively timed motor etc etc etc.
This could be a popular mod if we can figure out a basic configuration for it, me thinks it has been done.
