Gen 1 small block roller conversion with GM rollers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2007, 11:18 AM
I have a 1980 350 4 bolt block (gonna be a 383) that I want to convert to a roller cam. I have the 8060 vortec heads and plan to use self align roller rockers 1.5 ratio. I have found that the factory GM 4.3 v6 roller lifters fit the lifter bores, however I can't find anyone to ask if this will work? The oil feed hole on the lifter side is higher on the roller lifter but there is a feed channel that is around the mid section and looks like it would supply the oil to it! I can buy everything I need with a ZZ4 roller cam for about $175.00 new! But, I can't find anyone that has done this to ask if it will work.
Old 07-27-2007, 11:48 AM
No this doesn't work. Factory roller blocks raise the lifter boss nearly half an inch, without this the long rollers loose support and bind in their bores. Plus the way factory hydraulic rollers are kept straight on the cam is by a broached double loop device that ties pairs of lifters together. These are held in position by a sheetmetal guide that is bolted to 3 towers cast onto the main oil galley boss. Non roller blocks do not have these bosses, therefore there is no easy way to mount the spider.
There are ways to do this but unless you're a machinest with access to the proper tools and have the know how the cost of having a professional do the modifications to a standard block far outweigh the expense of just buying a roller block.
You can run a ZZ4 cam with aftermarket lifters, but they are expensive. The ZZ4 cam would have to be installed using a roller block thrustplate with the ears machined off and a roller cam timing set. Thrust would have to be accomplished with a thrust button as is done for aftermarket roller cams.
Not really practical, but at 175 bucks for the set up, I'd recommend buying it and putting on the shelf till I figured out what, if anything, I want to do with it. After all the wrecking yards are full of 96 and up Vortec 350 blocks which are built around roller cams and will accept all your 383's parts.
Bogie
Old 07-27-2007, 12:50 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Most 1986 and up 1 Pc. rear main seal 350's are also roller cam compatible. TBI trucks got a flat tappet hydraulic cam but the blocks have the taller lifter bores and retainer standoffs for the factory roller cam. Grab the ZZ4 cam setup and then get the correct block to go with it, it will be easier and cheaper in the long run and you'll love the 1 Pc. rear seal.
Another option is to use the Comp Cams XS262S-10 solid lifter cam instead. In DD2000 it makes just a tad more TQ and HP than the ZZ4 with an almost identical TQ curve.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 07:33 PM
GM Gen III/IV V8s Blazin72 Engine 14 10-05-2005 09:44 PM
Small Block Chevy Top End Rebuild: How Much HP?? purple1967camaro Hotrodding Basics 13 03-28-2004 07:38 AM
small block ford parts interchange k-star Engine 3 01-16-2004 10:35 AM
