-   -   gen 5 454 (http://www.hotrodders.com/forum/gen-5-454-a-144814.html)
BBCMudbogger 09-08-2008 02:51 PM
gen 5 454
Is there anything from the mark iv that won't work on the gen 5? I seem to get conflicting info. My buddy lost a rod in his mark iv block and has a gen 5. Should the solid roller cam and heads work with this block as well as the pistons and rods? They way I understand it you can use the old heads with the proper head gasket.
Double_v23 09-08-2008 09:35 PM
The fuel pump from the Gen IV wont work...there is no place for it on a gen v. Also the crankshaft is a one piece rear main on the 91 and up Gen V.
BBCMudbogger 09-09-2008 05:39 AM
No mech fuel pump req'd and I have an adapter to use a two piece seal. The biggest thing here is heads and valvetrain.
Double_v23 09-09-2008 02:08 PM
I think you should be good to go. Use the fel pro head gasket #1307 it covers all the gen iv and gen v motors and has the three coolant holes already in the bottom of the head gasket.
