Gen 6 454 Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2009, 09:43 PM
454headache's Avatar
Gen 6 454 Questions
Alright, three questions guys concerning the Gen VI 454 BBC.
First, in order to mount the oil filter, all I need is the threaded insert for the oil filter right? This little guy http://www.summitracing.com/parts/NA...n/?prefilter=1. Is GM the only ones that offer it, or would a local hardware store have it you think? I wonder what thread size it is.
The second is, does it need the crank reluctor ring? As in, will the dampener go too far in if I don't use one or for some reason not seal right? I'm not running EFI, or any other sensors, I'm just concerned that the dampener will go too far in if I don't use one.
The third question is about the oil pan and the oil pickup tube clearance. I know the rule of thumb is that the oil pickup tube screen should be 1//4 to 3/8" from the bottom of the oil pan. My OEM GM 6 quart oil pan came with a pickup tube and melling M77G oil pump (same thing as a M77). The problem is that, the pickup sits a full inch (1.10" without gasket to be exact) above the pan, ***! The pan is 9" deep. The pickup tube is 6.05" long. I tried a Melling 241S pickup tube that is used with 8 quart pans on Mercruisers. That tube puts the pan 0.90" from the tube. I am so frustrated, that I am about to cut the collection of pickup tubes I have, splice a section in, TIG it, and be done with it.
Old 07-24-2009, 10:24 PM
BOBCRMAN@aol.com's Avatar
That is the correct piece. Most blocks also have a required by-pas valve that also fits in that hole. Available from engine rebuilders/GM dealers.
Leave the reluctor, unless you rebalance motor and use earlier balancer or devise a spacer.
Check a Melling catalog. There are many different pickup tubes available. Also spacers to drop pump are available in the aftermkt.
Old 07-24-2009, 10:30 PM
There in lies the problem, I don't have the reluctor ring and I don't know how thick a spacer should be. I just TIG'ed the tube, so that's done.
Old 07-24-2009, 10:33 PM
I could use a GEN 4 balancer, but I don't know if that will even work, guess I could check it out.
Old 07-24-2009, 10:36 PM
Balancer/flywheel weight is wrong for GEN 5/6 motors.
Old 07-25-2009, 12:36 AM
Hmm, i might just not put in the reluctor. i dont really think it would hurt anything.
Old 07-25-2009, 05:42 AM
Balancer may rub on front cover, pulley alignment will be off.
Old 07-25-2009, 01:55 PM
Alright alright, I'll order the dang reluctor. I can wait until Tuesday I suppose, as I'm still having oil pump/pickup issues.
Old 07-25-2009, 07:24 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Your friendly Chevrolet parts people will have the pan, pick-up in an oil pan kit.
It is a 4qt pan to allow you to put the GenVI into most passenger cars.
I do not have the part number right now----but you might call the people at summit racing for more info
Old 07-26-2009, 03:00 PM
Almost got so fed up with the pickup situation that I ordered the 4 quart pan, but didn't. Ended up just cutting the pickup, and splicing in another section of pickup. What I do not get though, is that according to GM, this is the right pump, the right pickup, and the right pan. So why would the pickup sit a little over an inch from the bottom of the pan? Did the GEN 6 change things so much that now this is the new correct distance?
Old 07-28-2009, 09:16 PM
Well, got a so-called Gen 6 balancer, and guess what, there is no difference between it an a Gen 4. And because of the reluctor, it wont go fully in, yay.
454 swap in a 3rd gen chrismac Engine 4 07-29-2006 10:43 PM
454 BBC heads by FoMoCo?? WakBordr7387 Engine 9 06-13-2006 11:30 PM
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 04:38 PM
'74 Corvette 454 dyno results- Comp Cam XE 274H questions Bob Turner Engine 12 05-19-2005 11:59 AM
454 Gen V Valve Settings JDHBAJA Engine 2 02-04-2005 07:01 PM
