Gen I vs Gen II question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2004, 07:41 PM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Is the only difference in the Chevy- Gen I medium journal and the Gen II medium journal blocks the single piece rear main seal? Are all other parts interchangeable?
Thanks
MF
Old 05-04-2004, 10:17 PM
I stole this link from 68Impala...
http://www.mochevracing.com/Corvette/lt1lt4.html
it will tell you about the gen II block
Old 05-05-2004, 05:22 AM
Great help as usual!
Thanks for the link worknprogress72, and pass on the thanks to 68 Impala. That's what I like about this group. Somebody or sombodies, has the info you need!
Thanks Guys!!
MF
Old 05-05-2004, 06:26 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
The LT engines have a different water pump and stat hookup. The coolant goes through the heads first, keeping them cooler (you can run a higher compression on cheepie gas this way), ummm... I don't know alot of other differences.
Old 05-05-2004, 06:31 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Your answer is on this site. Just have to read a little.
http://hotrodders.com/kb/engine/data.html#chevrolet
Luv the smell of NITRO in the morning.
