gen light on 67 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 12:24 PM
The gen light is on when car is running.. I checked out the the alt and battery system and things are testing ok. It wasnt on before and cant find why its on. Car runs fine. The light being on for unknown reasons seems to be just an annoyance right now, but want to make sure im not overlooking something more serious
Old 05-01-2011, 02:51 PM
The way the light works:
If there is power on both sides it does not light (12 volts from ignition switch and 12 volts from alternator.
Power on ignition side only; alternator not charging - this creates a high voltage difference and it turns on.
If the light is on (and you have ignition power), you are undercharging, or it is finding a path to ground on the alternator side.
Bruce
Old 05-03-2011, 09:01 PM
dklong's Avatar
check your altrnator belt. what is your altrnator voltage output ?? if that is ok you may have a bad external regulator
Old 05-04-2011, 06:12 AM
generator light
Hello, I had the same thing happen to me after putting a new gauge cluster in my 67, Check the center screw at the top of the cluster, there is a ground wire loop metal thing that has to be grounded when that screw is installed, the screw is probably missing or the wire is missing, Good luck, Chuck
Old 05-04-2011, 06:08 PM
T-bucket23's Avatar
Wiki Edits: 26
Could be the regulator
Chet
Camaro Security Light on!! John L. Electrical 7 02-18-2011 08:06 PM
Red light on in 67 Camaro onefastchevy Electrical 3 08-04-2008 10:27 PM
break error light on 78 camaro? hcker2000 Suspension - Brakes - Steering 5 05-29-2006 07:09 PM
greased f. wheel bearings on 72 camaro, now brake light stays on bullheimer Suspension - Brakes - Steering 3 04-06-2006 09:43 PM
Bad Stop light?(brake light) A-BodyFan Electrical 7 03-09-2006 03:19 PM
