GEN V 454 piston question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2010, 08:05 AM
Hacksaw's Avatar
BOOMER SOONER
I'm having a hard time finding piston info on building a GEN V 454. I've been reading different things on weather you can run a mark IV piston in a gen V engine, piston skirts different, something like that. I don't see why it would matter, but that's why I'm asking. I picked up a set of 088 502 heads for the gen V. They have been cut for 2.25/1.88 valves and have been surfaced but only to clean up the head. The stock gen V comp is like 8.75.1 with the stock truck heads, which I know nothing about those specs other then there junk. I need to get the comp ratio up with those heads and for the .595 lift cam I want to run. Any ideas will help! Thanks
Old 07-25-2010, 08:26 AM
Hacksaw's Avatar
BOOMER SOONER
I looked at a set of KB207 -25.5 cc domes. They are hyperutectic pistons that should have arround 10.25 compression with my heads according to their web site. I just don't know if they will work in a GEN V 454???
Old 07-25-2010, 03:14 PM
BOBCRMAN@aol.com's Avatar
Just about any of the Mark IV pistons will fit a V block. Pistons are basically the same. Skirt design is not a problem. The KB 207 is an excellent street piston..
1st vs 2nd gen SBC question eocoolj Engine 3 07-09-2010 09:59 AM
454 Piston Question Wildman1 Engine 0 09-21-2009 08:52 PM
Gen VI GM Marine BBC distributor/intake question IHRodder Engine 0 03-12-2008 09:43 PM
Piston To Valve Clearance Question # 258,325 leejoy Engine 4 01-07-2008 05:40 AM
almost new 454 with one burnt piston clyde Engine 2 01-12-2003 08:18 AM
