Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gen V 454, what flexplate?
Old 05-29-2011, 10:06 AM
ethn_bert ethn_bert is offline
Last journal entry: Some More Roll Cage Fabrication
Originally Posted by hotrodcommuter
thanks for your help. It's price right! There are no specifications, though. I looked on summit, nothing. So yours could be perfect. How did you find out that's the one?
Like I said I had the same problem. The truck flexplates came with the large bolt circle for the torque convertor. The 700r4 uses a small bolt pattern. Unless you buy a torque convertor with both bolt patterns(check summit/jegs). That is the part number I used in my combination.
I ended up swapping out the 700r4 for a TH350, but same flexplate. The 700r4 lasted about 5 minutes before I ripped the 2nd band lug off.
It is a 153 tooth flexplate. I matched this flexplate with a 70 nova starter(my car) in order to utilize the bypass/relay circuit of the starter. Advance lists it as a high performance upgrade, but it is not SFI approved. Good Luck.
