GEN VI 454 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2006, 02:08 AM
GEN VI 454 build
Looking to build a 454 and was wondering where would be the best place to buy all the stuff I will need for a GEN VI block? Im also considering stroking it since Im going to buy a new crank. Any thoughts are great!!
Old 02-14-2006, 04:52 AM
Bumpstick's Avatar
Hammer and a torch
Summit, Jegs and most any other performance parts dealer will have Gen VI stuff... As with any BBC money is the only question...
Old 02-14-2006, 07:25 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
You can get a 1 piece rear main seal kit from Eagle. They stroke well with no block clearancing most of the time. Even at that, an adapter will allow a 2 piece rear seal crank to go right in. not a cheezy mod, it works great.
Other than that. The cam timing cover and oil pan are the only thing that will need to be Gen VI specific. Any generation cylinder head will work.
I've done tons of them.
Old 02-14-2006, 08:55 AM
Whats wrong with a 1 piece seal? Why do people convert?
Old 02-14-2006, 12:01 PM
Ozz1967's Avatar
Air Force Guy
As far as I know, nothing is wrong with a 1 piece seal...and it's actually better than a one piece. I've never heard of a 1 piece seal leaking, but I've personally seen several 2 piece seals leaking, and leaking pretty badly. I think the reason he says to do the convert is that most bbc cranks are of the 2 piece variety and it might be cheaper doing the conversion rather than forking out gobs of money for a custom build 1 piece. But I'm only hypothisizing here.
Old 02-14-2006, 12:44 PM
Infomaniac's Avatar
thanks - I mentioned the adapter in case he had a crank he wanted to use.
Old 02-14-2006, 04:08 PM
Ozz1967's Avatar
Air Force Guy
That's kind of what I figured. I just didn't know if he knew what the difference was between a once piece and two piece rear main seal.
Old 02-14-2006, 04:17 PM
I have noticed the variety isnt as large for the 1 piece cranks. I already checked with Summit and Jegs and they dont have a very large supply of BBC GEN 6 stuff.
Old 02-14-2006, 04:35 PM
Mustangsaly's Avatar
what yr are the Gen VI BLOCKS ?
Mustangsaly
Old 02-14-2006, 04:46 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I believe they were '96-'00 (and current Engines (502, 572)-
Old 02-14-2006, 10:13 PM
Ozz1967's Avatar
Air Force Guy
Your right 35Window...
Gen VI bbc motors are 96 and up. You can find a great listing of chevy block casting years here...this one is big block specific...
http://www.mortec.com/bbc.htm
www.mortec.com is the base site.
Also, the reason you don't find many 1 piece rear main seals is because the blocks are newer...in most cases, 1987 and newer I believe. So there just isn't as much call for them as of yet.
Old 02-15-2006, 08:12 AM
propaneburner's Avatar
Last journal entry: Artillery wheels
Scat sells the one piece mainseal cranks .
Std and stroker.
Hope this helps.
Old 02-15-2006, 02:21 PM
Do they have a internal balanced one? or should I stick with external?
Old 02-15-2006, 03:10 PM
Infomaniac's Avatar
It depends on if you want to buy a balancer and flywheel also.
Go internal if buying everything.
Old 02-15-2006, 03:45 PM
Yea, Im going new on everything
454 Build 48bill Engine 7 04-26-2011 04:53 AM
BBC 454 build ?? (long) bobbypantera Engine 16 04-30-2005 11:04 PM
What is the best way to build a 454 neil madsen Engine 4 11-15-2002 02:43 PM
Whats the best way to build a "under the hood" 454???? neil madsen Engine 3 10-31-2002 07:02 PM
Want to build 500 horse chev 454 79monte Engine 6 05-29-2002 09:20 PM
