Gen VI BBC cam oiling (sorta) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2012, 02:42 AM
Okay, on the Gen VI BBC the camshaft has the nose machined for a retainer that bolts onto the front of the block and limits cam walk. Why doesn't it wear!?!? If oil is able to get on the nose to lube it then why doesn't it leak from behind the timing chain? What am I missing?
Greg
Old 07-05-2012, 04:41 AM
BOBCRMAN@aol.com's Avatar
There is a wear factor, but not near as much as the old flat tappet cams. Roller cam engines have much less thrust wear because of the shape of cam lobes. Front retainer plate/thrust area is lubricated by oil cast off from front cam bearing, plus splash from chain. Also retainer plate is very hard/tough.. Oil does leak from between the timing set and block. But is minimal.. On the older blocks I sometimes create an oil leak in front to better lube the thrust on a flat tappet cam setup.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
ekacpuc (07-05-2012)
Old 07-05-2012, 09:53 AM
1971BB427's Avatar
Not sure about the Gen 6 block, as I haven't seen one, but previous blocks had oil return holes from the lifter valley to the timing area, so oil ran down the front of the block inside the timing cover also.
The Following User Says Thank You to 1971BB427 For This Useful Post:
Old 07-05-2012, 02:35 PM
Cool. I figured since GM did it that it's good to go. Converting my mark IV to run a VI cam (yes boss is ready for retainer dispite what some people say).
I was under the impression that hyd tappet lobes are ground at an angle. The lifters keep the cam from walking, plus the angle promotes lifter spin for even wear. So since hyd rollers can't have that angle there isn't anything to hold the cam in, therefore more thrust/cam walk pressures are experianced with hyd roller cams...
Greg
Old 07-05-2012, 04:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Greg
The flat tappet cams (as you know) are angled to provide rotation to the lifters, plus the angle helps offset the thrust caused by the distributor/oil pump drive gears. With a roller cam, the roller lobes are flat so there's no thrust induced by the lobes/lifters, but there's still the gear drive to the distributor and oil pump that causes the cam to walk forward- so the cam plate is used.
I've seen the BBC blocks like you have, that have the bosses for the cam retainer. I believe they were also used for reverse rotation cams, like for marine use.
Old 07-06-2012, 05:48 AM
I have 2 blocks like that... One i know isn't marine. I was originally told it was for a gear drive.
Old 07-06-2012, 01:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The gear drive rotated the cam in the reverse direction. "Marine" may be a misnomer, though.
bbc, gen vi
BBC Oiling Questions Wolf Wengler Engine 2 07-01-2012 10:31 AM
Gen 6 BBC Rocker Q 454headache Engine 2 09-10-2009 02:07 AM
Cam Failure, oiling problem?? bsorbe Engine 13 04-09-2009 08:25 AM
BBC gen 6 roller cam! Studebaker Engine 1 01-04-2008 07:13 AM
How does a Gen III SBC oiling system differ from Gen I/II systems? 70bird Engine 1 04-09-2006 02:13 PM
