Gen VI GM Marine BBC distributor/intake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2008, 09:43 PM
IHRodder's Avatar
Farm equip wasnt meant to fly
Hello. Im new here but not new to wrenching.
Im looking at buying a fuel injected 2003 or 2004 GM Marine Gen VI 454 BBC for use in a hot rod. It was in a boat, and I was told that the engine suffered an oil pressure failure, lost power, and has unknown internal damage, but still turns freely. It is offered for a really attractive price. The rich owner just tossed in a new engine and wants this one gone.
I realize that it will require a complete rebuild and I plan to change cam/heads/pistons/rods/crank as needed.
My question is, as I am not familiar with newer fuel injected GM BB engines, does this engine come with a provision to use a distributor? Not having actually see this engine, I dont want to assume that it will take a dist.
I plan to use a carb with this engine. If it will take a dist, am I correct in assuming that 4 bbl intakes and HEI distributors for this engine are just run of the mill late model BBC stuff?
Thanks for any help you can give.
Mike
Question on BBC Intake manifold Dmaleck Engine 4 01-18-2008 01:18 PM
GM Crate 502 question rajsid Engine 19 12-30-2007 08:54 PM
gm manifold question jsimerson Engine 1 11-13-2007 07:05 PM
BBC Crank Question inquiring_mind2 Engine 2 11-10-2007 08:18 AM
GM 4th gen 6-speed question Chief Pontiac Transmission - Rearend 0 02-04-2004 12:18 AM
