Gen VI Timing Cover/Double Roller Chain - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 08:17 AM
Kraneking's Avatar
I am currently building a 489 and I am using a brand new GMPP Gen 6 block. After going through 2 old Mark IV blocks that showed cracks when they were magged, I got tired of wasting my time.
Has anyone used a double roller timing chain in a Gen 6 and if you did...what timing cover did you use? The only one I have found is at Flatlander Racing and they claim theirs is the only one that will clear a double roller. I am going to list a few questions I really need help getting answered.
1. - Will a Mark VI double roller timing set work/fit in a Gen 6 block?
2. - What timing cover is there other than the Flatlander one?
3. - Is a long style water pump required or will a short style fit?
4. - Is the factory center to center (crank to cam) distance the same on all big blocks? (I am getting it align bored so I know it will change by a few thou)
5. - Is there any issues/things to watch for when choosing a hydraulic roller camshaft?
If anyone can help me with any or all of these questions that would be great.
Old 03-06-2010, 05:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
1. - Will a Mark VI double roller timing set work/fit in a Gen 6 block? {Do you mean Mk IV DR timing set in a Gen 6 block? If so, you need to match the gear to the cam. There are DR timing sets for the Gen 6 w/ Gen 6 cam.}
2. - What timing cover is there other than the Flatlander one? {Milodon and IMCO.}
4. - Is the factory center to center (crank to cam) distance the same on all big blocks? (I am getting it align bored so I know it will change by a few thou) {They are the same.}
5. - Is there any issues/things to watch for when choosing a hydraulic roller camshaft? {Use the lifters specific to the Gen 6.}
The little bit I know is contained in the quote above.
Good luck.
Old 03-06-2010, 06:02 PM
BOBCRMAN@aol.com's Avatar
Mark IV timing set won't work on later style roller camshaft. These have a thrust plate on block. Smaller diameter/bolt pattern. on the front end of cam. The correct double roller setup is available in aftermkt.
GM covers for gen 6, are the steel stamping (somewhat rare, has a big tab hanging down). Plastic and aluminum. I doubt if a short pump would clear the latter styles. I've always used long style and aftermkt electric pumps.
Production blocks are same center to center. Timing sets are available .005-.010" short. For align bores/hones.
Just keep the front components compatible. You can use early components with cam button and--- Retro (linked)hydraulic rollers. DON"T BUY THE CHEAP ONES!!! They are terrible quality.. Watch pushrod length..
Old 03-06-2010, 07:14 PM
35WINDOW's Avatar
Last journal entry: Engine!
Milodon makes a Timing Cover:
http://www.milodon.com/timing-covers/timing-covers.asp
Old 03-08-2010, 08:27 AM
Kraneking's Avatar
Well that gives me a better idea of what I need to do.
I am planning on a Comp XR264HR or XR270HR camshaft. Are Comp lifters a good choice or should I consider looking at another brand?
My heads are 781's with mild bowl work, larger 2.19 valves, new seats, Manley 11/32 valves and all Comp hardware. This engine will not be going past 5500 rpm and I am trying to make the most low-end torque that I can.
Thanks for all the replies.
Old 07-28-2010, 06:24 AM
gen vi timing
I am currently building a 489 also - I am using a gen vi cam - hydraulic roller - billet - in a Mark iv block - the opposite of you - I am using a rollmaster double roller gen vi timing chain with torrington bearing - a cloyes two pieice timing cover - the one for hex-a- just - just for the adjustable cam button option and a comp cams plastic distributor gear - as it is billet - this is the opposite of what you are doing - but I thought I would throw it out there
Old 03-01-2011, 06:27 PM
timing cover
competition products sells a cover for gen 6 i have a 540 and
it's the same one nice allum..like 45.00
Replacing the Timing Chain '64 Ford 390 Billy Boy Engine 14 12-26-2011 07:02 PM
Rough / no idle - bad timing chain? Arrowhead Engine 3 05-13-2008 06:48 AM
BBC gen 6 roller cam! Studebaker Engine 1 01-04-2008 07:13 AM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 10 12-01-2007 04:28 PM
gen v 454 marine roller motor 71javelin Engine 13 09-12-2007 01:52 PM
