Gen6 Vortec 454 Need help before its gone!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2010, 10:53 PM
Hey fellas. I need some info real quick. Ive done a lot of searching and cant find answers im lookin for. This engine is for sale local and it wont last long so if its gonna work ill go snag it pronto.
I have an 87 caprice with a 355 sbc and just the other day I bought my first big block, a 1981 454 out of a truck. I was going to take it apart and rebuild it and stumbled upon a Gen6 454 for $500 obo. Its all apart but all the parts are there. My question is which one would be the best option to put in my caprice equipped with a t56 6speed? Right now the 355 in my caprice is a 1 pc rear seal factory roller motor. I would need a different flywheel with the older 454 since its a 2 pc rear seal but would I need a different flywheel with the newer 1 pc rear seal 454? Are the motor mounts in the same location on the older and newer block or am I going to run into mounting issues and have to move the transmission etc..etc? Can I ditch the fuel injection and run a carb on the newer 454? Will I be able to use an hei distributor with this engine? I know it doesnt have provisions for a mech fuel pump and thats not too big an issue. Do they make aftermarket intakes to use with these vortec heads that accomodate carbs? Should I use the vortec heads or my set of 781's with some work done to em? Can i find headers for these or am i limited to the factory exhaust manifolds?
Is there anything im missing or not thinking of?
If this isnt going to work or be a big hassle over using the older one ill just forget it.
Old 03-31-2010, 12:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure there's no cracked castings or bad crank journals, overheated caps/mains in the block, etc. that you'll have to deal with. $500 is fairly cheap- caveat emptor and all that.
Either could be a fine engine. If the Mk. IV engine is complete w/decent heads (your 781's qualify) I'd just as soon use the Mk. IV engine, myself. The Gen 6 will be hydraulic roller ready, though- and that's something to consider w/the current state of affairs w/crappy oil formulations for flat tappet cams.
ANY externally balanced 454 will require a different flywheel than what you now have- they're (OEM) externally balanced, and have a different counterweight than a 400 or 1-piece RMS SBC.
Yes.
Yes.
Yes.
Some do, some don't.
Yes.
If you use the Vortec's you will need to convert them to an adjustable valve train.
Headers fit fine.
Probably the biggest advantage to the Gen 6 is the roller cam/lifters. And then the 1-piece RMS.
Old 03-31-2010, 12:22 AM
So Basically I'll have to buy a new flywheel anyway the newer one wont save me any bucks there. 1 pc or 2pc doesnt matter a whole lot to me in that case. Obviously i would prefer 1pc but its not a biggie. So really the only real benefit is the stock hyd roller setup which is why I thought about this engine in the first place. I'd have to buy an electric fuel pump with the new one where I wont with the older one. It might be better to stick with what ive got then. Do you fellas see any problem with running a solid flat tappet cam in the mark iv 454 if I choose my oil carefully and/or run a zddp additive? If im going to use the older 454 I would like to spare myself the expense and added valvetrain weight of a retrofit hyd roller setup unless it will just be the absolute best choice for a daily driver.
Looks like if I can use a mech flat tappet cam the mark iv 454 would be more of a budget swap. Are the vortec heads of the mark vi better than my 718s? should I put them on my older block?
Old 03-31-2010, 06:53 AM
BOBCRMAN@aol.com's Avatar
Your 781's are a better bet for horsepower. The big block Vortecs are for truck/torque use. Also when using a Gen VI, the flywheel/flexplate/balancer is balanced differently than the earlier big block. Earlier flywheels will bolt up, but you will have a mysterious vibration.
Vortec Heads on a 454 Torque454 Engine 2 02-16-2009 10:45 PM
454 intake, vortec to tbi HOUCKXLR8 Engine 0 09-12-2007 08:02 PM
454 Vortec question..Moved to engine forum 8kidsok Engine 0 04-10-2007 06:38 PM
88 350 to 98 vortec 454 swap RiPRiPPLeR7 Engine 0 06-29-2005 02:31 PM
96 vortec 4.3 to 97 vortec 454 rtrooster Electrical 0 01-07-2003 08:38 PM
