Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - General 302 Engine Reassembly
Old 01-11-2013, 05:35 PM
kaw550 kaw550 is offline
I ended up picking up the permatex #2. I forgot I had to get the paint.
Should I be worried that the new bearings do not have hole drilled on one side?
I also noticed that the rod caps we not all in the same direction. There is a small number stamped into the side of each rod and cap. Do I line that up or do I line up the number that is case into the cap?
I guess another way to ask is "do the small tabs on each half of the bearing but against each other?"
No threadlock on the cap or main bolts, right?
