-   -   General A/C clutch question (http://www.hotrodders.com/forum/general-c-clutch-question-223769.html)
brian12c 09-06-2012 06:22 PM
If the A/C compressor only makes noise when the clutch is engaged, could the issue still be in the pulley/clutch bearing?
The car is a 2007 Ford 500. The noise increases equally with engine rpm, but only with the clutch engaged.
Thanks
LATECH 09-06-2012 06:24 PM
Sounds like the compressor is noisy. The clutch wont act like you are describing.
boothboy 09-07-2012 09:24 AM
LATECK is right . In all likelihood you've got a bad compressor. That is assuming that all the nuts and bolts holding the compressor and bracketry are tight.
A bad bearing would make a light to heavy roaring sound depending the condition of the bearing with the compressor disengaged.
