General A/C clutch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2012, 06:22 PM
brian12c's Avatar
If the A/C compressor only makes noise when the clutch is engaged, could the issue still be in the pulley/clutch bearing?
The car is a 2007 Ford 500. The noise increases equally with engine rpm, but only with the clutch engaged.
Thanks
Old 09-06-2012, 06:24 PM
LATECH's Avatar
Sounds like the compressor is noisy. The clutch wont act like you are describing.
Fact is stranger than Fiction
Old 09-07-2012, 09:24 AM
LATECK is right . In all likelihood you've got a bad compressor. That is assuming that all the nuts and bolts holding the compressor and bracketry are tight.
A bad bearing would make a light to heavy roaring sound depending the condition of the bearing with the compressor disengaged.
General U Joint Question riesman20 Transmission - Rearend 14 10-25-2007 07:37 AM
General Question...Firewalls OneMoreTime Hotrodders Site Suggestions and Help 4 11-04-2005 08:35 AM
general question dirtrules General Rodding Tech 15 01-22-2005 05:54 AM
General 12 Bolt question Damage Transmission - Rearend 3 07-01-2004 06:18 AM
general electrical question Vaughn68 Electrical 2 01-28-2003 04:04 AM
