general electrical question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2003, 01:42 PM
Vaughn68's Avatar
New Member
Post general electrical question
Would a 17 amp output from my alternator cause my tach to go haywire and some accesories not to work or should I bee looking for something else. the alternator is only 6 months old and the tester says all is ok except for the overcharge.
Old 01-25-2003, 02:04 PM
5.0Towncar's Avatar
Post
17 volt you mean? Do you not have a voltage regulator at all? If not, then I am not suprised the battery hasn't exploded and wires burst into flames. Steve
Old 01-28-2003, 05:04 AM
Tazz
Cool
Over voltage will Kill. Replace the voltage regulator if it is seperate from the alternator, if it is built in replace the alternator. You will kill the battery, lights,anything electric might be killed.
Todd
[ January 28, 2003: Message edited by: tm454 ]</p>
