general engine mount question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 09:14 PM
I have a 55 chevy pickup that im putting a 350 into. Now I bought one off those engine crossmember adapters that are made out off black pipe that has the sliding sleeve on both ends. I have never used one before so first question is are they worth a crap. It just seems mighty lite to me. And second question is once you have it in and bolted to the frame should you weld the sleeve so it wont pivot. I was concerned that welding the sleeve would make the pipe brittle and cause it to crack down the road. Not a good situation to have.
Old 02-19-2012, 09:59 PM
Prof. T. Soggmeyer's Avatar
Plan B
I have one in my 49 5w p/u and it's ok. Yes, you do have to weld the tubes together. two things I don't like about it are 1.) the tube comes down farther than if you fabbed mounts yourself and 2.) the motor mounts are a P.I.T.A. on my 49 when installing the motor due to the fact that you have to come straight down into them.No front rear jiggle room.
...Brad..
n
Engine mount question? 39chevy Engine 2 08-14-2011 01:25 PM
Engine mount question v8muscle Engine 2 07-16-2008 08:12 PM
SBF into Dogde D50 engine mount question.. Deep Sleep Engine 1 02-21-2006 08:20 AM
engine mount question pigjamelectric Engine 8 06-23-2005 04:01 AM
Engine Mount Question Nightfire Hotrodding Basics 5 04-01-2004 11:15 AM
