Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - General Engine Question: FML (Ford, Mercury, and Lincoln)
Old 03-19-2012, 08:16 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hey Dave,
Thanks for the response. So you answered the main question, and that is all the companies did always use the Ford blocks as the foundations. The different displacements and power outputs is to be expected.
Since you did bring it up, what is the standard angle for the Ford blocks, vs the oddball 30 degrees (I hope I worded all of that correctly)?
Also, which parts will usually not interchange?
Thanks!
