General Guidelines - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2012, 09:46 PM
General Guidelines
Is there a general rule of thumb as to how much wider the rear tread of a car can be than the front tread before you encounter handling problems. Wouldn't a much wider rear make the car too twitchy or "darty" ??? What is the minimum clearance you should have between the inside of the rear wheels and the body of a fenderless car to avoid tire rubs during heavy cornering ???
Old 10-31-2012, 10:10 PM
Faith - Respect - Trust
Way to Many variables in your question...What kind of tire, how tall a tire, what kind of sidewall, what type of tread pattern, what is the rubber compound, what kind of rear suspension, how fast are you cornering, you need to be more specific.
Old 10-31-2012, 11:05 PM
327NUT's Avatar
Simple answer is no, If you have wide tires on the rear and skinny's up front like most hot rods do.....and for whatever reason THAT ALONE is causing a handling problem then you are driving waaay too fast on city streets. Also depending on what kind of car you're talking about, the type of suspension and whether it has a good sway bar/anti-rollbar....and how fast you take corners I would say at least 1"-1 1/2" between tire and inside of wheelwell. As 69 said...way too many variables.
Old 11-01-2012, 09:36 AM
The issue isn't rear tires that are too wide, it's front tires that are too narrow, especially since most RWD cars have more than 50% of the weight on the front tires.
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 04:57 PM
Guidelines for body restoration? unstable Body - Exterior 3 02-18-2003 01:01 PM
