general kinetics cam shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2010, 07:40 AM
I have had these 2 big block engines in my garage for 25 years. I took them out the other day to see what i had . I found your web page to be very helpful. One engine has TRW pistons but i could not find them in your listing so if anybody could tell me they are trw l2307f . the other question is a general kinetics cam # c2m-332-b 881 su thanks and great web site
Old 04-21-2010, 09:52 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
TRW Forged Dome Pistons
Pn is L2307F +.030 and are 12.5:1 CR, their for the open chamber heads 119CC
The cam? General Kinetics was bought out by Lunati, then Lunati was bought out by Holley
Contact Lunati
Tech Line: 662-892-1500
Hours: Monday - Friday 7AM - 6PM CST
Fax: 662-890-6309
Address
11126 Willow Ridge Drive
Olive Branch, MS 38654
Old 04-21-2010, 04:45 PM
BOBCRMAN@aol.com's Avatar
General Kinetics C=chevy 2=big block M=solid lifter 332=advertised duration of intake valve b=second revision of cam grind, this can be different centerline, different exhaust lift or duration. I would assume the 881 u is a cam core number..
Old 12-30-2010, 10:03 PM
c2m-332-b was a mechanical grind GK produced for use with automatic
transmissions. Basic specs .631 In/Ex lift, 332 dg advertised duration,
286 dg @ .050, 108 dg lobe separation angle, hot lash .027 both IN/EX.
As a side note, been looking for that cam for a nastalgic race car
project if your interested in selling it!
Old 01-16-2012, 11:55 PM
C2m332b
The C2M332B was the solid lifter cam of choice for Big Block ProStocks of the early 70s, used by Bill Grumpy Jenkins, Wally Booth, Warren Johnson and a myriad of others.
I believe the B version was ground on 108* centers. Itr was 332* duration at .020 lift and I believe .632 lift with 1.7 rockers.
Dave Colbert
General kinetics cam dado Hotrodding Basics 2 11-09-2009 05:14 PM
need specs for cam shaft crane CD 10007B mikestatum Engine 2 10-23-2009 02:24 PM
Cam Shaft Identification BadA$$37 Engine 4 02-10-2008 11:28 AM
noob question intake cam shaft kit RAUL78 Engine 1 08-11-2006 09:10 AM
General Kinetics Cam help bgibson23 Engine 4 02-01-2006 05:01 PM
