general kinetics cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2012, 08:06 AM
I just found my old GK catalog from the late 70"s. If anyone needs cam info let me know.
Old 07-18-2012, 01:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A scan of it would be great to have in the data base here or at the Crankshaft Coalition wiki, even if it was just the Chevy section.
Old 07-18-2012, 04:55 PM
I am not sure how to do that but i will see what i can do.
Old 07-18-2012, 11:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Scanners are often found built into copiers. You'd scan it and save it to your computer then upload it to the Hotrodders Photo Gallery here on the forum or an image hosting service for display.
Old 07-19-2012, 06:20 AM
I will check with my better half to see if she can do it. I still type with one finger. Either way i will find someone who can.
Old 07-19-2012, 08:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like a plan. There is a surprising number of calls for specs on the GK cams as you may have seen.
Thanks for the effort.
Old 07-19-2012, 03:33 PM
I was cleaning house and found the catalog along with one from holly carbs. I almost tossed it but decided to see if they were still in business. Figured i would keep it and help out those who needed the info.
Old 07-22-2012, 11:47 AM
E.T. divided by $ spent= Speed
Is general kinetics still in biz??
Old 07-22-2012, 11:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't believe so. They became part of Holley ca. 2007, then what became of them I cannot say.
Old 07-22-2012, 12:09 PM
That suks! I remember seeing them still listed in Summit about 10yrs ago they had a line of SBC cams with the same specs as Comps Magnum cams.
What about Cam Dynamics,didn't Crane buy them up for there Energizer line??
Old 07-22-2012, 05:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You know, I do believe I remember seeing that somewhere.
There's a guy who posts over at yellowbullet, speedtalk, etc, named UDHarold (UD for Ultradyne, I believe). He was the man behind several of the big-name cam companies and he has posted several times on the links between several of the cam makers, at least as far as his contributions to them- which were considerable. You might try a search for more info on it all.
General Kinetics Cams cbxjim1 Engine 14 01-16-2012 10:47 PM
General Kinetics Cams JOEMUDBONE Hotrodding Basics 4 01-06-2011 02:10 AM
general kinetics cams (need specs) wardogpappy Engine 2 04-25-2010 02:42 PM
General Kinetics Cams LittleJoe Engine 5 03-14-2009 10:32 PM
General Kinetics Cams one_aceracer Engine 3 11-17-2003 06:17 PM
