general kinetics cams (need specs) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2010, 10:06 AM
have a General Kinetics cam like to find spec only # on cam are 274 and l cm 5 looks like a capble C with a m in the middle
Old 04-25-2010, 12:19 PM
BOBCRMAN@aol.com's Avatar
General Kinetics C=chevrolet 1= small block M=solid lifter 274=advertised duration of intake lobe. Then usually a letter that denotes a revision of original pattern. A being the orig and B and later being revisions.
If you can find an old Crane cams book The General Kinetics grinds were for the most part similar to Crane Energizer series.
general kinetics cam shaft storyman1001 Hotrodding Basics 4 01-16-2012 11:55 PM
comp extreme energy cams 86SSman Engine 10 03-13-2010 12:12 AM
Comp Cams Xtream Energy 268 camshaft chevymastermind Engine 15 05-22-2007 06:15 PM
camshaft specs and good replacement mybad66 Engine 2 01-11-2007 04:48 PM
Truth about, emmisions and cam's stereodud Engine 16 11-18-2002 04:25 PM
