General Lee Paint job for 100 dollar 83 Subaru I bought - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2012, 05:46 PM
I have access to a paint booth.
My plan in general is to :
Pressure wash
180
Mask
Tack
Spray
1500
Buff with compound
Done
What I am unsure about is two things. In what order, and how should I mask off for the flag, General Lee, and 01? The second thing is what kind of paint should I use?
Being that it is a 100 dollar car, the worst car I've ever owned or ridden in, I wanted to spend about a hundred bucks on painting it. However it seems that oil based enamel (rustoleum), while meeting the cheap requirement does not dry in a day. The DuPont polyurethane with accelerator and hardener we use at my work for repainting semi trucks and trailers drys to the touch in about an hour. However, I don't want to spend a couple hundred bucks on painting a car that not only do I want to jump to death next year is also rusted through in several areas. So what should I paint my 83 Subaru with?
Old 11-11-2012, 06:03 PM
novafreek6872's Avatar
Nova Guru
I believe Valspar makes a farm implement enamel that can be bought with hardner...its cheap but Im not sure how quick it dries. Enamels like rustoleum can be thinned with Acetone instead of mineral spirits and they will dry much quicker... hope this helps you
Oh, instead of the 180, I would use 320
Old 11-11-2012, 06:08 PM
Nova Guru
Heres a link about a guy who used the Valspar... I'd definitely try it out on a beater...
The ULTIMATE budget paint job (pic heavy) - Third Generation F-Body Message Boards
Old 11-13-2012, 07:50 AM
I use rustoleum paints a lot on signs. Laquer works better to thin, but takes a while, usually at least overnight. If I need one done fast, cut it with acetone. Makes it fast, usually dries to touch in and hour or so.
Also, Tractor Supply now carries the Majik line of tractor and implement paints. sell paint, reducer, and hardener. you could get an allis chalmers orange that would be close to the color of the general, it lays down quick and easy, is pretty durable, and with the hardener, helps add gloss. They even sell a rattle can of touch up. Painted lots of stuff around the shop and farm with it, mostly low gloss black. Been pleased so far.
Old 11-13-2012, 08:00 AM
Faith - Respect - Trust
Pressure wash
180
Mask
Tack
Spray
1500
Buff with compound
Done
You want to 1500 the car and buff????and "want to jump to death next year is also rusted through in several areas"????Why bother, your going to spend almost as much on 1500 paper and compound as you are on paint????I don't get the logic!
Old 11-13-2012, 08:30 AM
Nova Guru
saw that last night at TS. $30 a gallon and $15 for the hardener... definitely an option for a beater/work truck/farm truck type thing
Old 11-13-2012, 11:45 AM
ogre's Avatar
the 'Duracell Project'
home depot has latex paint for cheap
Old 11-13-2012, 12:02 PM
Wiki Edits: 31
I don't think latex will do very well. The price difference between a cheap automotive SS Acrylic and a gallon of tractor enamel is about $0 but the shipping on that $30-40 gallon of auto paint will tack on another $20-30..
$35 for a gallon of Valspar tractor enamel and $15 for a bottle of hardener. Add in some mineral spirits or even their branded reducer ( both will work ) for well under $100 and it will dry in a day and stay nice for 6-12 months. likely look 'decent' thru the duration of the $100 Subaru's lifespan.
Old 11-13-2012, 12:05 PM
poncho62's Avatar
Wiki Edits: 5
Why does everyone talk about shipping when pricing anything these days?...Is it too much trouble to get off ones arse and go to an auto parts store, tractor supply or whatever? I live in the middle of nowhere and an auto parts store and tractor store are about 10 minutes away
Ontario Rodders
Old 11-13-2012, 01:35 PM
gearheadslife's Avatar
MentalMuffinMan
I have better luck with big rig fleet parts stores. for cheap paint..
don't know what the difference (if any) over the tractor paint.
I do know the local bodyshop/autoparts jobber.. doesn't sell cheap paint..
a pint of 77vette yellow.. so I could accent my rally wheels to body color..
in a single stage was 70.oo then add reducer and activator...
that was nasan brand (dupont cheap line)
but eastwood/summit sell mighty cheap "hotrod" paint.. tho..
shipping adds to it.. it's still cheaper.. than what the local jobber lines cost..
the limits I've come across is color choice in the big rig paint thats mostly for the frame/dump/etc than the cab..
Old 11-13-2012, 05:35 PM
Nova Guru
Summit shipping is dirt cheap on paint and supplies... I ordered $300 worth the other day... shipping was 12 bucks... Maybe some people dont have the time and money to run all over town, burning gas, to hunt down supplies... doesnt mean they are lazy couch potatoes.
Old 11-18-2012, 06:37 AM
When you drive to the store to get it does it not cost anything then? Is there something I've been doing wrong my entire life?!
Old 11-18-2012, 06:49 AM
poncho62's Avatar
Wiki Edits: 5
Point was that when you go to whatever store it is, the part is there...no shipping cost.....and the price is generally the same as you would order online, without the extra shipping cost......And, yes, I think people are just generally lazy today.....I can see ordering online if you cant get it anywhere else, but that seldom is the case
Ontario Rodders
Old 11-18-2012, 06:54 AM
Well there was only one person in the thread who had mentioned shipping, which is not 'everyone.' I think you just woke up on the wrong side of the bed today.
Back to the subject at hand, TSC no longer carries that Valspar paint, just the Majik paint or whatever the hell it is, and I've been told it's a step down.
Old 11-18-2012, 07:18 AM
MentalMuffinMan
na.. autosurply stores have delivery trucks for a reason..
time= money...
Good 10 dollar paint job....... 79C10 Body - Exterior 8 11-14-2007 07:25 PM
The General Lee redlightning Hotrodders' Lounge 25 05-09-2007 11:34 PM
Any helpful info on GM fair or job hunting in general? 78novaman Hotrodders' Lounge 5 04-20-2007 09:04 PM
My job possibly bought out zonk Hotrodders' Lounge 2 05-20-2005 07:51 AM
The General Lee 68Velle Hotrodders' Lounge 7 07-30-2004 02:49 PM
