general machining tolerance question (not just automotive based machining)
ok, the reason im asking IS because of an automotive project, but im sure theres plenty of aplications thats are similar, but not automotive based, hence the title
lets say you took a throttle body off a fuel injected car and overbored it 5mm whats an acceptable tolerance for maching the hole "on center" ? if the hole is .0045" off center (in reference to teh shaft) is this considered "acceptable" tolerance for a simple butterfly valve? if not, what is ? |
That specification is set by the designer of the part as to what he thinks is acceptable..An example is that some tolerance may be there to provide idle air or he may want to get a good seal when the buttrefly is shut..One of those "it depends" sort of deals..
Good enough is good enough..I know this is not much of an answer to your question..but laets look at say overboring an engine block..we may spec out a clearance of say +/- 0.0001 or 0.0002 on the bore diameter..in the throttle body we may spec out +/- 0.0020 t0 0.0030 tolerance on the bore..we are still boring holes but it depends on what we are after as to how much tolerance we can tolerate in a particular piece.. Sam
Holding perpendicular bore axes within 0.005 is very difficult when you're chucking up a part in a single axis milling machine. The original part, however, was machined in a computer controlled multiple axis machine and I wouldn't be surprised if the print tolerance was plus or minus 0.002!
Now, as to whether the part you have will be satisfactory: We've all experienced intake leaks...usually associated with carburetor or manifold gaskets...which were far in excess of a couple of thousandths. I would go ahead and install it. I don't think you'll have any problems. |
best i can figure, a stock unit is .008" off-center
my modified unit is .0045 off-center guess im within factory spec
In the aerospace world, regular machining tolerances are +/- 0.030". We use +/- 0.010" only when necessary due to cost. +/- 0.001" is reserved for special needs due to the cost of achieving it. The throttle bore in question is more than close enough at +/- 0.0045". So long as there is adequate adjustment in the screws that hold the throttle blade to the shaft to allow it to be centered in the bore when the throttle is closed, you'll be fine. As you point out, the OEM tolerance is even larger.
.030???? I can do that with my bench vice and a drill press. You must mean .003 and .0001 when needed. Most decent machines can hold .003. |
| Recent General Rodding Tech posts with photos |
| US General tool box question | buzz1961 | Garage - Tools | 36 | 12-23-2011 12:46 PM |
| Info on the Mustang and a general question... | SkyMan9600 | Hotrodders' Lounge | 15 | 02-28-2005 05:33 PM |
| engine question just not automotive question | chevelle_502 | Hotrodders' Lounge | 115 | 08-13-2004 01:11 PM |
| General 12 Bolt question | Damage | Transmission - Rearend | 3 | 07-01-2004 06:18 AM |
| General Carb/FI Question for y'all | Locutus | Engine | 14 | 12-21-2003 12:04 PM |
