General Motors 350 Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2007, 04:49 PM
My daughter located an engine that she is trying to ID but the numbers she gave me don't add up either. She says the numbers on the block are V0421CWI but I can't reference them, Can someone help me?
kickstart
Old 09-02-2007, 05:14 PM
302 Z28's Avatar
Are you sure it is a 350cid? The numbers are as follows.
V= Flint plant
04=april
21=21st day
CWI= big block 454 1973 250hp
The suffix CWI does not cross to a small block.
Vince
Old 09-02-2007, 05:16 PM
The casting number you need from the block is on the driver's side, on a flat area just behind the valve cover. If the engine is installed in a vehicle, you are usually looking straight down, just to the left (passenger) side of the power brake booster. Since this area is flat, it will have collected any oil and dirt from valve cover leaks, and it might be hard to read.
Bruce
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 Chevy Issues engine trouble... Please help me! ineedspeed Engine 26 07-28-2008 04:23 AM
350 engine liljoe5811 Engine 1 08-25-2005 09:48 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
