general question - single cam vs twin cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2009, 09:49 PM
what is the difference? why would you want two camshafts in a car?
Old 09-22-2009, 11:17 PM
SSedan64's Avatar
Normally twin cams are used with 4-valve heads, 2 Intake & 2 Exhaust valves per cylinder. This allows for much smaller valves, springs & retainers which means much lighter valvetrain that is more stable at Hi RPMs = Higher RPM capability.
Old 09-23-2009, 10:41 AM
Mostly cost, weight and space. Dual over head cams do offer some tunability in that one or both cams can be advanced or retarded by speed sensitive mechanisms which essentially results in a variable Lobe Separation Angle (LSA). This is mostly useful on smallish engines typical of the Euros and Japanese of years past where varying the LSA can be used to recover some bottom end torque at one extreme and add some top end horsepower at the other.
Frankly, back when I had a 1987 Alfa Spider Veloce, I found it far more effective to take the variable timing, twin cam, 4 banger out and put a 5 liter small block Ford in. Not quite as easy a swap as I make it sound, but well worth the effort.
Bogie
Old 09-23-2009, 10:57 AM
sqzbox's Avatar
My pipes are my music
Can you imagine the lobe count on a 4 valve system V-engine? I think it would br virtualy imposible. One thing about overhead cams though, They eliminate valve lifters and are quick to change.
Old 09-23-2009, 02:46 PM
Banned
you mena like a Ford mod motor? Or the Northstar?
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
Another Cam selection question NWayne Engine 17 02-01-2007 12:28 AM
cam question dboyett38606 Engine 8 01-23-2007 02:13 PM
350 cam question Camaro1980 Engine 6 07-24-2005 05:35 AM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
