general transmission question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2007, 05:55 AM
excaliberprime's Avatar
Last journal entry: back for 2014
ok i now have what i believe to be a th200 transmission. should i swich to another transmission for better performance. i have a 1976 cherolet c 10 with a 350 that i expect to build into the 400 horse power range. the truck is not a daily driver but i do want to be able to drive in to town from time to time any idea what auto transmission would be ideal. im lost when i comes to transmissions.
Old 03-02-2007, 12:59 PM
general trans question
If you have a 200 trans,and you have 400 horsepower,you will end up with a badly disfigured 200 trans.
A TH350 would be a wise choice for this application.
Old 03-02-2007, 09:00 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
quick way to tell... take a peek under there and look at the tailshaft housing. If it has a bolt-on housing, its a 350. If its cast as one piece, its a 200.
Old 03-17-2007, 09:12 PM
fast68's Avatar
likes chevy trucks & boobies
be aware though
a 350 can actually be a 250
if its a 6" tail anyways
big X across the pan = 250
run away fast
good luck
Old 03-17-2007, 09:51 PM
DesertrusT's Avatar
Jailbar Revolutionary
http://www.drivetrain.com/autotranscrossref.html
Old 03-17-2007, 10:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by fast68
be aware though
run away fast
good luck
actually a better way to detect a t-250 is look at the cooler line fittings area. IF there is a stud with a nut on it that protudes from the case.... it is a t-250
1972 Mustang Grande transmission question demitristewart Engine 5 07-31-2005 07:27 PM
1994 Grand Am Transmission fluid question StevenC Transmission - Rearend 0 07-18-2005 10:23 PM
Question about astro van transmission??? Robbie Transmission - Rearend 2 05-27-2004 01:50 PM
Question about a crazy looking transmission ravenandrews Transmission - Rearend 5 04-25-2004 03:44 PM
General Carb/FI Question for y'all Locutus Engine 14 12-21-2003 12:04 PM
