generation of current - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 02:14 AM
Is it possable to burn out , or render unservicable a generator , by continuing to use this to generate charge in an unservicable battery
Old 06-12-2009, 07:36 AM
bobjob's Avatar
probably burn up regulator first...
Old 06-12-2009, 04:29 PM
Yes
Bogie
Old 06-13-2009, 07:49 AM
generator burn out
Bob
thanks - yeah , as the battery case is cracked , and the resulting ground means the battery is flattened , the voltage regulator is registering a constant demand , probably causing this to overheat and fail .
thanks Bobjob
First Generation Hemi Guy 345 desoto Introduce Yourself 4 07-02-2008 03:13 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
Turn signal blinking too fast? Jughead Electrical 26 06-20-2005 04:51 PM
427 or 454? frankenvette Engine 50 06-05-2005 10:12 PM
