Generator - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2010, 09:22 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Generator
I have a US General brand generator given to me that doesn't generate electricity. The engine runs well. At full running RPM I get no power reading at the recepticals. What other checks can I do to get an idea what wrong with it?
Old 06-07-2010, 05:31 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
The best test to try is flashing the field. Take off the back cover (before doing this take a peak at the windings just to make sure nothing is obviously toasty) then take the leads off the brushes and secure them out of the way, put a set of temporary leads on. The positive brush is usually the one closest to the bearing. Start the engine and then hook your leads to a battery. The generator should come up to close to full voltage. If it does there is a problem in your excitation circuit. Could be a capacitor or a voltage regulator or another problem (hard to say off the top of my head with no print). If it doesn't make voltage while flashing the field then you have a problem with your rotor or your windings. You can check the rotor with an ohm meter slip ring to slip ring.
This applies to brush type, if you have diodes in your rotor one of those could of failed. However they can't be tested in circuit and have to be de-soldered which is kind of a pain so it's best to try and eliminate other stuff first.
If you need any more help feel free to PM me I'm a generator technician by trade.
Good luck and hope that helps
Pat
AC Generator Problem Torque454 Garage - Tools 8 11-30-2013 08:07 PM
24v jeep generator skeeveman Electrical 5 09-12-2007 03:53 PM
Chevy Alternator from Generator ddove1972 Electrical 5 09-05-2007 03:17 PM
54 Chevy Generator Problems..? Flaco54 Electrical 10 04-09-2007 03:43 PM
Generator trouble barkingspider Electrical 9 01-20-2007 05:45 PM
