Generator
Hi guys,
I just moved to Florida and want to purchase a Generator. What do you guys suggest? What do you think aout this one from Northern Tools? Thanks Powerhorse Portable Generator with Electric Start — 9000 Surge Watts, 7250 Rated Watts | 7,000 - 9,999 Watts| Northern Tool + Equipment Dave |
I suggest a very quiet one. Would u buy a used one ?
I had a 'regular' 6500W generator - and the I/C Briggs & Stratton engine, while 100% reliable was LOUD and sucked gas like it was free. I sold it and replaced it with a 3600W inverter type. Much quieter, much less gas use as it only runs at rated speed if the load is there. You neighbors might even thank you. The best rated are Honda and Yamaha but by far the most expensive - which means that my $950 Boliy was a good deal for me. Oh - and the Hondas can be linked together
Once upon a time I used to teach emergency preparedness courses
I am assuming your concern is "when the power goes out after a hurricane" In that case the question you want to ask is "How SMALL a generator can I use?" The bigger the gen, the more gas it sucks. The corner gas station is not gonna be pumping gas any time soon, so the gas you have on hand is whatcha got. Which is better - one that can keep your food from spoiling for 5 days on that amount of gas, or one that will run the whole house including the air cond for 3 hours? |
i believe the ?? is...
just what do u want to run with it ???? i live in the country so noise is not a problem.. i got the elect start 7500w from harbor fright. used it last wkend after the storm for 12 yrs.. ran whole house except the air.
2 fridg's, well pump, lighting, etc.. didn't need the air on but it was getting very close.. |
I have 2 gens.
a 3500w that I use in my trailer for most everything. It will even run the A/C but not much else. I have a 12kw Powermate that will run anything. Mostly it is used to drive my TIG welder when I'm out away from plug in power. I have loaned it out to several friends ( who each made it worth while) to run their homes during power outs. Both of thes make noise. I surely would not to run the 12k one in a campground even though it has idle down feature. The 3500 is not too bad if it has something over it like a large cardboard box with intake and ex openings. The 3500 is pretty easy on gas especially if only driving lights. The 12kw ......well it uses gas proportionately to it's output. About 1 1/2 gal per hour sometimes more when I'm welding. |
I have a Generac 8K and it works great. Starts easy and has a good size fuel tank. Its not real loud but it can get annoying.
I also have a small 2500 Craftsman but the gas tank is so small it is a pain to keep running. The inverter type are very quiet but don't handle long term heavy loads, especially resistive loads, well from what I have read. Several friends have the Harbor Freight units and they seem ok. Not the same quality as the Generac or other big names but they are also priced considerably less. They key is to be sure to maintain it. I start mine once a month and let it run for 15 minutes with a small load then I let it run out of gas. This keeps the carb free of gum and crap. I do this with all my gasoline powered equipment and never have issues. I only keep 3 or 4 gallons of fuel on hand as I figure I can always drain on of the cars if needed.
Artificial Intelligence is no match for Natural Stupidity Chet |
I just moved southern Florida and I am preparing for when we lose power after a hurricane. It could be for a few hours or days. Who knows?
But I would like to run the A/C, fridge, and some house lights. Never had one before so I'm not sure what to look for. Thanks Dave |
I still have my Yamaha 6600kv generator that I bought right after the 1981 ice storm. It has taken me through three hurricanes and resides now in North Texas ready for the next malady. This time however it has been converted to run on natural gas. I highly recommend Yamaha and Honda generators the price difference is worth it IMHO. I will never buy a generator with a Briggs engine on it, too much mechanical noise and gas consumption is too high.
Vince Last edited by 302 Z28; 07-09-2012 at 04:20 PM. |
Generator Sizing 101
The biggest mistake most people make when buying a generator is buying the wrong size-too small and the result is not being able to run the equipment you need.too big and you need to deal with heavy fuel consumption and excessive noise. The key to getting it right is to make a realistic list of what you want to run and the electrical requirements to run it. Most appliances have a data plate that will list the voltage and amperage needed- simply convert the data on the nameplate to watts by multiplying volts by amps and total up your list.
To just run essentials- refrigerator,a few lights,maybe a tv or computer,you'll find you can get by with a 5Kw generator or smaller,but if pumps,a/c or heat get involved,the generator you need is going to be larger. As an example, a typical central a/c unit will require 30 amps at 240 volts,or 7200 watts. An all electrically heated home may need 15,000 watts just for heat. An electric range is usually sized at 8Kw .Calculate the maximum load of all equipment that will be used at the same time( you won't be running heat and a/c at the same time,right?) and you'll be able to determine the smallest generator that will be able to do what you want to do. To promote longer life for the generator and allow some room for future needs,I suggest you get a unit at least 20% larger than your present needs. **** VERY IMPORTANT ****** When hooking up your generator-MAKE VERY SURE that there is NO possibility of back feeding power into the incoming service of your house. It is very possible to feed power into the utility company's distribution network and electricute one of the linemen who is trying to restore power to you. The best way to avoid this is to have a qualified electrician install a properly sized transfer switch and show you what to do to set up and run your generator. |
Backfeed WITH an interlock will work too, and they are cheaper than a transfer switch, but if an interlock kit is not available for your breaker box ( interlock panel with a breaker ), then you have to go for a transfer switch.
| Recent Garage - Tools posts with photos |
| generator | randob63 | Electrical | 3 | 01-19-2012 03:41 PM |
| Generator | johnsongrass1 | Garage - Tools | 1 | 06-07-2010 05:31 PM |
| generator help need | hotrod64 | Electrical | 1 | 05-30-2007 12:56 AM |
| Who has a generator? | 454me | Off-Topic | 21 | 10-01-2005 05:40 PM |
| Generator vs Alternator/ac vs dc | El Raton | Electrical | 2 | 10-21-2004 02:40 PM |
