generator or Alternator ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 08:01 AM
I've got a '49 Ford F-5 COE (truck) with the flathead V-8, which has the original 6 volt generator. How can I switch it to a 12 volt alternator ? I'm refferring to the mounting brackets....looks like to me ...both belt adjustments are on the bolt???? and a wrap around kinda mounting bracket .... so how do make a bracket for the Alt ???????
Old 03-15-2010, 08:43 AM
Joe G's Avatar
Well, if you can get by on 60 amps, here's one option.....
http://www.gener-nator.com/index.htm
Old 03-15-2010, 09:08 AM
I like gener-nator thing , but for $900, it's kinda my whole truck budget !
Old 03-15-2010, 01:21 PM
Joe G's Avatar
This looks to be a more economical route - never heard of this company though.....
http://www.qualitypowerauto.com/catalog.php?item=65
Hope this helps....
Old 03-15-2010, 01:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One option- that may or may not work for you (depending a LOT on your fabrication skills and a little less on how you plan to use the truck)- is to mount the alternator under the bed and run it off of the drive shaft.
Old 03-15-2010, 05:47 PM
I like the bracket that "Joe" os refferring to...actually thought of making something like that.......but, in this 'Cab Over' there ain't much room to get in there and mess with the fan hub and all....... Cobalt ; driveshaft sounds like something I could do also, but this truck will not see much high speed use, mainly in the feilds to haul firewood in from 'outback'.....it would have to have a large pulley on the driveshaft............
