Did you use the 59 regulator for the 59 Generator ? You need to use the regulator for the alternator. Some place I have a drawing. The regulators with 4 posts are for cars with an idiot light in the dash while there is a 3 post alternator regulator for cars with ammeters.
Bob willisb@kos.net http://members.kos.net/willisb/ |
I've done a few GM alternator conversions. Never tried to use the regulator wires, but this is the no brainer way:
I'm assuming you have the old syle internal regulator alt with the single pole on the back and the 2 prong connector on top. Attach the wire that goes to the battery to the back of the alt. Next, with the 2 prong plug installed, pigtail the larger of the 2 wires directly to the same single post on the back that holds the batt wire. This leaves only 1 small wire left over that comes out of the 2 prong plug. Use your existing "Field" wire (make sure it is hot with the key on) and connect it to the left over wire. This is the exciter wire for the field. You can actually use any hot source (12 volts is OK) for the energize wire, but you may end up with feedback issues which would cause the engine to continue running even with the key off. Using the existing field wire from the voltage reguator should make it work just fine. On the off chance you do end up with a feedback problem, a cheapo 2 or 3 amp diode from Radio Shack will fix it. Simply put it in line with the energize wire. Make sure it is installed in the right direction. The colored bands toward the alt as I recall. This will allow the current to flow in one direction only and alleviate any problems. Hope this helps. Mike |
Doc here,
Here ya go: ![]() Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thanks, Tim |
Thanks, Tim |
