generator to alternator swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2005, 01:07 PM
I am changing a 64 fairlane to an alternator. Can I get a Wiring diagram?
Old 11-04-2005, 01:48 PM
? are you asking for the normal 60's Ford alternator wiring configuration?
Old 11-04-2005, 04:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Tons more info needed...
Is the New alternator a single wire, Or a 3 wire?
Internally excited?
Will it be internally regulated or externally regulated?
Will you be using the idiot lamp on a 3 wire? (won't work on a one wire)
let us know, we can help more..
Doc
Old 11-05-2005, 05:46 PM
I plan to use a late model 80 amp alternator
Old 11-05-2005, 05:49 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That doesn't help...
Need to know:
Internally excited?
Doc
Old 11-06-2005, 03:54 AM
yup, need all the info Doc' asked for
? do you really need 80 amp? If not then I would use a std 30-40 amp, it's alot safer depending on the condition and wire sizes of all the harnesses.
Old 11-08-2005, 05:17 PM
It will be a 3 wireEXTERNAL REGULATOR,WITH NO IDIOT LAMP,AND i GUESS I`m not surewhat you mean by externally excited. What ever was stock in the late 60`s
Old 11-08-2005, 06:27 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
INTERNALLY excited is when the Alternator has a jumper between the two terminals on the plug, and provides 12 volts to itself, as opposed to 12 volts on one, the monitoring lamp/fuse on the other..
Doc
Old 11-09-2005, 06:55 AM
attached stock Ford general wiring diagram...???....first time try at a "upload", dang! it worked! so here's a second good one for all the wiring
Name:	alternator wiring diagram.jpg
ID:	7746   Click image for larger version
Name:	alternator and ignition wiring.jpg
Old 11-09-2005, 04:31 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
MY ERROR!
That, and I'm in the midst of reprogramming a new hard drive, (my 250 gig drive died with my data base on it.. )
Sorry about, my bad...I thought we were talking about a GM until I went ALL the way back to the first post in the thread...that was so many posts ago, I lost track...
Red65mustangs Diagram is correct and proper for your vehicle. Use it..
And Thanks ! Red65Mustang For the save...
Doc
Old 11-09-2005, 06:10 PM
your welcome Doc,
